I love it when bass hits my chest in a music concert or in an action movie. Its tactile power just invites for more and you just can't get enough of it. Don't you agree?
A while ago, I was looking for a new subwoofer. I made a list of finalists and I'm going doing this overview on one of those subs: the Klipsch R-115SW Subwoofer.
Why this sub?, you may ask. Simply put, I've always been a Klipsch fan. This company has been around for almost 70 years and I have a great deal of respect for a company with such an admirable history. With so many years you can expect them to know a thing or two about sound quality and how to achieve it. They carry a wide variety of subs, but it was their R-115SW that got my attention. I was looking for a sub with a 12"-15" driver, a good amplifier section and wireless capability and the R-115SW was perfect for all my specific needs. Why? Read on!
This sub features a 15" spun-copper Cerametallic driver that is light and rigid at the same time - both good things to find in a subwoofer. Its has a front-firing slot port with proprietary internal geometry that, according to the company, minimizes port noise and provides cleaner sound. All this controlled by an all-digital amplifier pumping 400-watt of continuous power (800w Peak). For the greatest placement flexibility, add an optional Klipsch WA-2 Wireless Subwoofer Kit for a simple wireless connection. And on top of that, it also has a power status indicator which means no more getting up from your seat to find out if it's on or off. To me, this is a another winner from Klipsch.
Check out the following features and specifications and let us know your impressions!
SOME FEATURES:
- 15" spun-copper Cerametallic woofer.
- All-digital amplifier delivers 800 watts of dynamic power.
- Front-firing slot port with exclusive internal flare technology.
- For a simple wireless connection, add an optional Klipsch WA-2 Wireless Subwoofer Kit.
- Gain, Lowpass, Phase, Auto Power
- Made from durable MDF cabinet, the R-115SW is finished with a brushed black polymer veneer and satin painted MDF plinth.
- Front-mounted LED power indicator that lets you know the power status of the system.
SPECIFICATIONS:
- Frequency response: 18Hz-125Hz +/-3dB.
- Maximum output: 122dB
- Amplifier: All digital
- Amplifier power (Constant/Peak: 400W / 800W
- Drive components: 15" long-throw copper spun cerametallic, front-firing woofer.
- Phase: Switchable 0-180 degrees.
- Enclosure material: MDF
- Enclosure type: Bass Reflex.
- Inputs: L/R line-level/LFE RCA jacks, Wireless WA-2 Port.
- Height: 21.5"
- Width: 19.5"
- Depth: 22.3"
- Weight: 75.4 lbs.
- Finish: Brushed Black Polymer Veneer.
Price: $899.00/each.
You can click on the thumbnail below to zoom in.
