not sure why you need to understand, but essentially i like bass
I know why you want to add a sub, but, I still don't understand why the effort to integrate one to THIS Kef set.
i think this thread has already proven that options are limited
Correct. There is no easy way to integrate a sub to THIS Kef set.
you appear to be incorrect, if that's not the case, please prove otherwise and detail the "innumerable options" you've just referenced (an integrated amp with a line out will not work....so wrong again)
I'm picking up a miscommunication/misunderstanding. I was referring to options not involving THIS Kef set. An integrated amp with line out will work, but, not for THIS Kef set.
talk is cheap, time to show your "knowledge" partner
I suspect the irony here is lost on you.
based on your input on this thread.......I suspect...............you cannot
To be honest, if you remain fixated on adding a sub to THIS Kef set, I really don't have much to offer. If you are interested in 2.1 options with a different powered speaker, I'll make the effort to enumerate the possibilities.
