I see this in the manual:
You can not output audio using the AUDIO OUTPUT under the following conditions:
That refers to the Fixed level L&R Analogue Audio outputs and I have tried with and without HDMI. Even with the HDMI cable not even inserted.
The output of the STB is Analogue to the JVC. So when I am using Analogue Input 1 ( Motorola STB ), the Fixed level L&R Analogue Audio output works. If I switch to HDMI Input 1, the Fixed level L&R Analogue Audio output does not work.
Under any/all of the conditions, I have no visible light emanating on the FO cable when connected to the JVC like when I connect it to the Motorola STB.
AUDIO MENUS:
There are two Audio Menus. One has to be chosen from the Remote and that is "
Audio Effects" for Movie or Music ( AHS ), ATC, Smart Sound and Hyper Bass [
Hyper Bass greyed on when I use Analogue Input 1 ].
The second is via the Main Menu and it provides Bass, Treble and Balance as well Turn-On Volume and Volume Limit.
There is nothing about Speakers On/Off or Internal/External sound output.
