Jamo has been around for some time now and I decided to do some overviews on some of their new speaker products. Take a look at the C-10 SUR Surround Speaker for example.
This speaker features high-quality cabinetry which is hand-polished, it has satin painted MDF baffles, polished chrome logo, satin aluminum trim rings, center plugs and stabilizer feet. It is a 2-way sealed surround speaker using two 6-inch woofers and two 1-inch decoupled tweeters. It is available in High Gloss Black finish with satin-painted MDF baffles for a premium. Check out the following features and specifications for more details and tell us what you think!
FEATURES:
- Hybrid composition conical cones that are said to provide a smooth midrange.
- In order to improve low frequency response, Jamo’s new line incorporates a long displacement surround design for midrange drivers and woofers.
- To reduce distortion and improve high frequency extension, the new Concert Series has a re-designed silk dome tweeter diaphragm.
- Anti-Diffraction Waveguide (ADW): Provides improved off-axis response with more uniform high frequency extension.
- Hybrid Composition Conical Cone (HCCC): Provides the stiffness and strength of aluminum or titanium, with the transient response and smoothness of wood fiber.
- Tweeter Distortion Reduction (TDR): Provides lower distortion, greater high frequency extension and smoother high end.
- Long Displacement Surround (LDS): Provides cleaner, tighter, deeper bass.
- Neutral Phase Surround Technology (NPST): Maximum detail with minimum phase distortion with front speakers.
- Can also be used as Left/Right surrounds and Rear Left/Right surrounds interchangeably.
- Aluminum center-plug: Eliminates cone breakup for faster attack and increased vocal clarity.
- Additional voice-coil cooling reduces power compression.
- Dual, 5-way binding posts: Allows bi-wiring/bi-amplification with multiple connection options with wire up to 12 gauge (AWG).
- Enhanced Anti-Diffraction WaveGuide.
SPECIFICATIONS:
- System Type: 2-Way Sealed NPST.
- Tweeters: Two 1" silk dome decoupled tweeters with Anti-Diffraction WaveGuide and Tweeter Distortion Reduction.
- Woofers: Two 6" Hybrid Composition Conical Cone woofers with Long Displacement Surround technology.
- Product dimensions (HxWxD): 13.8" x 15.7" x 7.9".
- Frequency Response (Hz, +/-3dB): 65Hz - 27kHz
- Power Handling (Long/Short Term): 160w / 320w
- Impedance: 6 Ohm
- Sensitivity (dB, 2.8V/1m): 87dB
- Weight: 21 lbs.
- Finish: Black
Price: $1,400/pair.
Click on the thumbnail below to zoom in.
Do you like it?
