Based on their past history with processors, I decided to hold off on the UMC-1 until those first round guys slog through the issues. I think they are a great company, but expectations are really high as well. With them not being a multi-billion dollar global company, the development of something like the UMC-1 is definitely going to take longer for them, so it is understandable and I don't fault them for it. In the meantime though, I will continue to enjoy my amp
I think the last update took care of most issues. I'd say they just need to work on the O&M manual to eliminate a lot of the questions and problems. I was lucky enough to get a
very early copy of the manual for review. The present edition has come a long way and will answer most questions if you take the time to read it first.
But hey, were guys! We don't need no stinkin' manuals!
I'm still playing with mine a little at a time to figure my way around. I think I got the hang of the EmoQ system. I may be wrong, but I think it can only adust
+10db. So if any particular channel needs to go further up or down it can't make the adjustment. So when I saw
+ 10db during a calibration I would raise or lower to amp gain for that channel the opposite direction and re-run the process again till the numbers were reasonable. Obviously the rear channel speakers will not be able to reach the same db as the fronts, so they always came up with +10 db. And the subwoofer channel for me always came up with -10db. So I adjusted the gains to get them in the range that EmoQ could handle adjustments.
I'm sure it's not the right way or the way Emotiva intended things to work, but it works for me. Even running the calibrations a few times after I acheived balance, the numbers are almost always the same. So the UMC-1 must be happy with the results.
I will say that I have cut the subwoofer channel down a few more db then EmoQ wants to set things at. Just seemed a little "hot" for me. Impressed the heck out of my neighbors.
Maybe this weekend I'll run a few sweeps with my laptop and see how it really performed.
Back to the OP's question:
I'd say I'm happy with Emotiva and their products that I've had a chance to own and play with. A really nice bunch of people that really do care about their customers. I own some of their speaker and the UMC-1. Looking to buy a stack of mono block amps this year for my theater and hopefully add the XMC-1 to the mix.
It's just amazing how many people complain about Emotiva products and won't make a simple telephone call. Chances are you might even get one of the primary designers, Lonnie Vaughn, to answer the phone. You'll probably get
way too much info, but you'll have a better handle on what the device you're having troubles with is capable of.
