The whole issue of chasing infrasonic frequencies in home audio is a dead end. Practically you only need to go to 25 Hz, and 20 Hz at the very outside. Chasing lower stuff is a pointless endeavor and an unnecessary expense.
I think there is a lot of bunk about room responses and its consequences. As usual the problem is speakers and not most rooms.
When people speak in mot rooms their speech is not chesty and hard to understand. Play it though a speaker and it very well may be.
I have on occasions been lucky enough to have live musicians play in my home and it sounds fine. So a speaker should to, but they so often do not.
This is where I believe speakers that play fast and loose with time get into trouble. In addition there are still too many high Q designs out there, that really cause trouble.
Good speakers deliver good sound in almost any room unless it is a real dog. There are some. But the natural speech does not sound good in those rooms either.
I don't have any room treatments and have a room of very average dimensions. I'm never really aware of room problems.
So what does it look like.
Here is the response of my main speakers.
As you can see the -3db point is around 20 Hz. The HF roll off is an artifact of Omni mic.
Smoothing is 1/24 octave.
So here are the room responses with all 7 speakers playing including the LFE channel, 1/6 octave smoothing.
First a front row seating position
There is a peak maximal around 100 Hz of 10 db.
Now lets look at a rear row seating position. The blue curve is the rear, the red curve the average of front and rear seats.
So the end result is that the rear position does sound marginally better then the front row.
The front row still sounds very good with excellent speech discrimination and sounds in no way boomy. If the speakers were higher Q there probably would be a big difference between front and rear seats. As it is the difference is actually very subtle.
There is no equalization used such as Audyssey or REW.
As usual this problem is mainly speakers and NOT the majority of rooms.
