System= JBL JRX118sp crossed at 100hz feeding two behringer B212A's as mid and hf. for this project sub im using a BBE MaxX3 Xover feeding a QSC GX5 pushing two channels @ 700/4ohms to a bi-amp terminal with the jumpers removed on the back of the project sub (each driver gets a channel). I realize this new sub might be overkill for the behringers and JRX, but it will be use in a broad variety of systems. what im looking for is SPL at relatively low distortion that can be driven 6 hours at high power.
as far as the drivers, I want to use it in live pa applications (parties)...has to be tough for when i haul it to locations and blast it all night.
I'm pushing this sub with a QSC GX5 (500/8ohms 700/4ohms) and i plan to use 4 ohm speakers so the amp can provide higher power to them as opposed to 8 ohms...
I was raised on JBL. all my buddies use JBL for live application and they seem pretty tough (we host music events in the mountains...lots of nasty abuse) But JBLs are pricey (666.00) for the two i was looking at. my price range is 400 for the pair.
as far as modding the box goes, I was thinking of simply taking a skill saw at 45 degrees and trimming 4 or 5 inches off the depth all the way around and reattaching the rear panel to the newly angled cuts. this would drop the displacement to about 6 cubic feet from 8.
should i think about wave guides?...sorry for all the newb questions, I just realy want this project to turn out well. once again thanks so much.
