Some of their speakers had fuses in the past, so you might want to start there. Otherwise, I would look for a wire not being connected to the binding posts or at the crossover. Usually, a speaker that is damaged makes sound from one of the drivers (e.g., woofer, tweeter, midrange) in the cabinet, so it is likely that there is a bad connection in the wiring that would affect all drivers.
