So I am resigned to an in-ceiling set up in my new house build. I have narrowed it down to either the AIM7 Twos or the AIM8 Ones mainly because of pricing. I can get both speakers for the same price. Which one would you prefer?
This is for a family room (17x27), TV above the fireplace. The family room is an open concept, opens right into the kitchen. Ceilings are 10 feet. Thank you for any and all help!
Here's the specs:
AIM7 Two
Pivoting and Rotating 7" Resin Reinforced Fiberglass Cone Woofer
Pivoting 1" Silk Dome Tweeter
Timbre-Matched to All Two Series Speakers
Front-Mounted Treble Equalization Switch
Sensitivity: 90dB 1W/1m
Power Handling: 125 Watts
Impedance: 8 Ohms
Frequency Response: 40Hz - 20kHz
Diameter x Depth: 9 7/8" x 5 1/8" (251 mm x 130 mm)
Cut-Out Diameter: 8 1/4" (210 mm)
AIM 8 One
Pivoting and Rotating 8" Injection Molded Polypropylene Cone Woofer
Pivoting 1" Treated Silk Dome Tweeter
Timbre-Matched to All One Series Speakers
Sensitivity: 88dB 1W/1m
Impedance: 8 Ohms
Diameter x Depth: 11 7/16" x 5 3/4" (291 mm x 146 mm)
Cut-Out Diameter: 9 3/4" (248 mm)
