I NEED TO GET WIRED: Electrical Connection Advice
Discussion in 'A/V Interconnects, Cables & Power Conditioning' started by Thrill Killer, Sep 12, 2017.
  1. Thrill Killer Audiophyte
    Thrill Killer
    Sep 4, 2012
    8
    0
    I'd like some help on getting a Power Strip to plug my gear into. I can't afford a Power/Voltage Conditioner type unit. So, I need the next best thing. Another reason is Convenience. Keep everything plugged into 1 unit. Instead of cords going here and there to a few different outlets.
    I'd also like to change the power cords out too. The stock ones are generic for the most part. Serviceable, yes. But I might as well go a bit further in having all of my components have a better than stock power cables and connectors too. That way I can make them Custom Lengths. So that all of the power cords are not laying everywhere like a Drunk Octopus. But in neat orderly lines to the PS.
    I do not need Exotic, Pricey, or Highly Reviewed Power Cables. As I don't have that kind of gear or budget. Just stuff that would work well.
    I would like to buy the power cable in bulk. So I can create the lengths that I need.
    As for the plugs, I would buy those with the cable. I would like them(cable) to be insulated as to not create upon each other. Some kind of interference? between them, if that's something to worry about.
    I don't have a budget because I know nothing about the subject at hand. But, if Hard Pressed, I'd say $250ish?
    If anyone can post some DIY links. Articles, How-to's, Others post, Advice,etc. All would be welcome.
    1. AMP: MacIntosh MC30 (C)
    2. AMP: McIntosh MC2205 (L/R)
    3. AMP: Emotiva XPA-3 (SURR)
    4. PRE-PRO: Marantz AV 7702
    5. SUB: SVS PB-1000
    I Thank You All.
  2. mtrycrafts Audioholic Slumlord
    Aug 19, 2004
    16,307
    1,382
    Monoprice or bluejeans for your cables. No need to change the power cables. Will do nothing except eat up you budget. Both may sell the bulk wire.
    • Agree Agree x 1
  3. Thrill Killer Audiophyte
    Thrill Killer
    Sep 4, 2012
    8
    0
    Thanks for the link. But I already have speaker cables, etc. I'm just looking for a good power strip. And to make custom length power cables. So my power cords won't be a jumbled mess. But, can be laid out in a orderly fashion. As my components won't all be the same distance from the power source. And they won't be in a rack. But on custom Cherry Wood platforms. That will sit on the floor. All made by a local furniture making shop. That had lots of leftover thick boards from building tables. So the power cables for my gear are going to get custom lengths. We get cables "to order", or DIY to length. Just the right length of speaker cable from speaker to power source. The same will be for my components to the power strip. As they all won't be the same distance from the source. I don't want to use zip ties for the shorter runs. As that would look ugly. I also don't want the other cables laying about in a jumbled mess.
  4. slipperybidness Audioholic Spartan
    slipperybidness
    Jul 24, 2011
    5,438
    1,203
    @Thrill Killer
    Standard advice is that upgrading cables is a waste of $ if you are looking for better performance. But, you are looking for aesthetics, and that is an OK design goal that is often overlooked on this particular forum. This forum tends more towards "all the $ for performance, don't care so much about aesthetics".
    Personally, I like this power strip. I have 2 in use in 2 different systems and been using these for 6 years now! What I really like most about it is the swiveling outlets! You often have a few wall-wart power supplies that will cover more than 1 outlet on conventional power strips, and this solves that problem. To nit-pick on this power strip, the power button can be a little finicky with pushing it in/out. I have not really had that problem, but you will see a few complaints on the Amazon reviews. I don't really use the power button often anyway.
    https://www.amazon.com/gp/product/B000JE9LD4/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    Now, about the custom lengths of power cords. If it were me and my gear, I would likely just go to Home Depot or Amazon and buy a thick, high quality 100 foot extension cord, and hack that up to the lengths that I need for my various power cords. You may be able to find something cheaper or better in bulk, but this is a solution that is readily available!
    Something like one of these:
    https://www.amazon.com/US-Wire-7405...814&sr=8-3&keywords=heavy+duty+extension+cord
    https://www.amazon.com/Coleman-Cabl...14&sr=8-10&keywords=heavy+duty+extension+cord
    • Like Like x 1
  5. BoredSysAdmin Audioholic Overlord
    BoredSysAdmin
    Aug 21, 2007
    11,422
    3,650
    New Joisey
    Slip usually gives solid advice, but I strongly believe that he's not providing you best advice regarding neither power strips nor custom length power cables.
    Triplite makes great noise filtering power strips and nothing wrong with wanting custom power length cables, but I strongly urge you NOT to try and make them yourself. Have them professionally made. AC power is not to be messed about. Above mentioned Blue Jeans cables makes custom length speaker cord, not sure for power, but it's worth checking with them.
    I'd also check Amazon for premade different power length cables.
  6. slipperybidness Audioholic Spartan
    slipperybidness
    Jul 24, 2011
    5,438
    1,203
    Haha, well, like I said, if it were me and my gear. And, I am absolutely qualified to build power cables, done it for industrial applications and it is trivial to me.
    I was just answering his questions, and nobody on here had even attempted to do that yet.
    Yeah, I'm not saying that the power strip that I linked is the best, I'm just saying that 2 of those have served me well for 6 years now.
    I do agree that Triplite makes excellent products.
    1 item to clarify, and likely we are both in agreement here, but I personally don't put much (none) faith for any "surge protection" that are advertised on any "cheap" power strips. It's really more of a "power outlet splitter" in my opinion.
  7. BoredSysAdmin Audioholic Overlord
    BoredSysAdmin
    Aug 21, 2007
    11,422
    3,650
    New Joisey
    The key word is professionally. I don't bring my PC to local geeksquad, nor should you pay for another person to make your power cables :) .
    Agreed on power strips in general, but some vendors are a bit better than others and IMHO I'd never consider Belkin one of better ones. Tom's hardware has several fairly technical articles on power devices disassembled and analysed, like this one:
    http://www.tomshardware.com/picturestory/661-power-strip-bar-surge-protection.html
  8. slipperybidness Audioholic Spartan
    slipperybidness
    Jul 24, 2011
    5,438
    1,203
    Hey, thanks for the link, I'll have to give that a read when I get a chance.
    hahaahah, yeah, I bet if you took your PC to geeksquad, those bozos would just end up pissing you off! ;)
  9. Pogre Audioholic Ninja
    Pogre
    Jul 29, 2016
    3,747
    1,017
    Not sure that bright yellow or orange would fit the bill for aesthetics! :p
  10. Thrill Killer Audiophyte
    Thrill Killer
    Sep 4, 2012
    8
    0
    The power cords will be for aesthetics. I just want them laid out nicely. I'm not looking for "Improved Performance". Just a nice custom look. I just built my own custom speaker cables for this set-up. I used to have Blue Jeans Cables. Which are great. I don't consider myself an electrician. So, I wouldn't go ahead and connect the power cords to any particular unit if I don't feel comfortable with it. No IEC connectors on the units will be used. Just 16-14ga cord and some kind of plug.
  11. Thrill Killer Audiophyte
    Thrill Killer
    Sep 4, 2012
    8
    0
    Thank You, @BoredSysAdmin
    The Triplite AV Series surge protectors look great.
  12. mtrycrafts Audioholic Slumlord
    Aug 19, 2004
    16,307
    1,382
    If the present power cable is not detachable, have you considered just cutting the existing cable to length and just add a plug?
    • Like Like x 1
    • Winner Winner x 1
  13. BoredSysAdmin Audioholic Overlord
    BoredSysAdmin
    Aug 21, 2007
    11,422
    3,650
    New Joisey
    ISOBAR6DBS is one I'd be looking if you're looking for a bit better product. Line filtering design could help you with ground loops (if any) - could be real lifesaver in some setups.
    • Like Like x 1
  14. Thrill Killer Audiophyte
    Thrill Killer
    Sep 4, 2012
    8
    0
    They aren't detachable. So, your idea is tops for me. I hadn't thought of that.
  15. Thrill Killer Audiophyte
    Thrill Killer
    Sep 4, 2012
    8
    0
    This seems like what I need. It's now in my Amazon Audio "Wish List"
Share This Page
  • CEDIA
