Wow, just WOW!!!
1) You are wasting $ on Kimber. If you want audio luxury jewelry, then go for it. If you want better sound, then spend the $ somewhere that will be an improvement, and not the snake oil that you are headed towards.
2) The difference in length will not make a difference to the sound, assuming that the AWG is sufficient for the power that it needs to transmit.
3) The guy at Audio Advisor was an idiot.
4) Your tube amp has high levels of THD (as compared to any solid state amp). In the big picture, it's pretty silly to be worried about some possible,maybe, not really, improvement due to speaker wires!
5) If you want a true improvement, buy a modern solid state amp, add a subwoofer, or add room acoustic treatments.
