Hi,
I just purchased a Niles SPK-1 switch and want to connect it to my Yamaha RX-V675 AV receiver. I want to use the 12v trigger out on the receiver to activate the switch. However, I am having a heck of a time finding a cable that will work as the receiver has a 3.5 mm (1/8") jack but the switch wants bare wires. After reading some other threads on here about 12v trigger cables I decided to try to put something together and want to make sure I'm doing it right
I went out and bought a 3.5 mm mono plug to mono plug audio cable from The Source, cut one end off, and stripped the outer jacket. Inside is a stranded wire core surrounded by some rubber and then more stranded wire around that. To connect to the Niles switch do I just pull all the outer wire together and twist it up and connect that to one terminal and then strip back the inner rubber, twist together the inner stranded wire and connect that to the other terminal? Then plug the other end in to the receiver?
I don't want to mess anything up so any help would be greatly appreciated.
Thanks!
