Thanks for you're response about this cable Problem
Sorry about two messages I didn't realise there was a Cable specific section and I don't know how to delete the other post if it is at all possible
Ok so you said an informative post would be best
I hope by informative you mean the type of connector otherwise you'll have to specify
Stereo Connectors TRS X1 1/4, X1 3.5 both male
http://www.maplin.co.uk/p/35mm-plastic-stereo-plug-hf98g
http://www.maplin.co.uk/p/35mm-metal-stereo-plug-fj99h
I used the same connector but in it's 1/4 inch form could find it online
so at one end 3.5 male stereo - 1/4 in male stereo
if you need the cable type I can't give it and can find it online
__________________________
About the metering I was away with my family so couldn't get back quicker
and don't have my own meter
all my meter readings were 1.7 average none above 2.0 which would be a short as i've learnt
there are no connections where there shouldn't be.
yet they all have the same problem with no vocal or only part the vocal
One of the guys at the electronics place were I am learning to make this cable it's kind of a place where people who are into electronics make stuff
he said, "Is the input the right input for this cable and I told him about the one cable I made that did work correctly which was exactly the same connectors / cable as the others unfortunately, that cable was messy in the 3.5 connector and the soldering wasn't very strong so inevitably the connections inside have now broken.
The only difference I can think of with that cable is I used the braided wire for the ground but not for the others.
I hope you can help I feel I' ve hit a brick wall
