I think this probably is the best place to ask this question. This isn't directly related to HT or Audioholics, but there are a lot of really smart forum members here that have a diverse wealth of knowledge, so I though I would at least ask.
I am having avery strange problem with my lawn sprinkler system. I regularly maintain all of it including replacing valves, solenoids, water valves and sprinkler heads.
I have one zone that turns on okay (solenoid opens water valve and sprinkles the area). When the cycle finishes it trips the ground fault circuit breaker into which the transformer of the sprinkler timer/eletronics is plugged.
The 5 other zones work fine. And if I disconnect the faulting zone there is no problem.
I checked the wiring of the particular control valve and can not see a problem. Since the solenoid is working I didn't think it was that. However, I tried relpcing with a brand new on and the same circuit breaker trip occurs. The trip seems to occur at the end of the cycle when the solenoid shuts off.
I tried further to isolate and actually connected the failing zone to another good zone. Both work correctly , but at the end of the cycle the circuit breaker trips.
I really don't want to run a new wire, but right now that seems like the solution. It would be a lot easier to solve if it didn't work well enough to water the zone. The partial working and partial failure isfrustrating.
Thanks to all who read this and respond!
Peace
, Good Sound
, Good Video
and effcient running sprinkler systems
Forest Man
