The TOA does not have “speaker wire” inputs, because there is no such thing as a component that sends speaker outputs to the input of another component.
I assume you mean the inputs are screw terminals, as that’s not uncommon for TOA’s input modules. However, they are line- or mic-level inputs, just like the RCA jacks on home theater gear.
Basically, you’re supposed to cut the connector off the cable, strip back the insulation, and crimp spade lugs to the shield and center conductor. The spade lugs are then inserted under the screw terminals.
If that seems ridiculous, it’s because the TOA is designed and manufactured for commercial-installations. Commercial installers don’t use off-the-shelf cabling. They do all cabling and terminations on-site from scratch with rolls of bulk wire.
RCA speaker cables could be used, but they are not shielded so you may end up with noise, especially for a 50-ft. run.
Alternately, you could replace the modules you have. AFAIK TOA does offer modules with RCA inputs.
Otherwise, make sure the modules you do have are for line inputs and not mic inputs.
Regards,
Wayne A. Pflughaupt
