I saw it on Kijiji. I went to the seller's home and he turned on some music on relatively low volume and I heard the STF-3 working just fine. He turned up the music to around middle volume and the sub's power and volume were quite evident. I felt underneath and the driver was moving normally.
I can't see any aspect of its handling that would have jarred anything loose... he disconnected it, and loaded it into my car's rear seat, with the front side down on the seat and the amp side up. I transferred it into my house carefully, it wasn't dropped or anything.
I've hooked it up to a Denon AVR E-400, which has a single subwoofer output. The sub has dual inputs for the Low Level Input. As per instructions, I've hooked up the sub cable to the white, left Low Level Input. Phase is set to 0. Crossover is switched to 'out', to allow the receiver to do the job. The power light is green when the switch is 'on' or in the 'auto' position. So I assume it's getting a signal ok. The volume dial is set to 2:00.
But the volume is incredibly low. Like, barely noticeable.
I've tried everything I could think of, even stuff that shouldn't make a difference. I've played with every control on the sub itself, I've tried a Y cable to have both inputs on the Low Level of the sub getting a signal, I've cranked the volume dial on the unit itself. I have used a different sub cable to see if that was it.
Still the volume is very low. I know it's getting something...I can feel the driver moving but barely.
On the Denon, I had to crank the subwoofer level to 10.5/12 just to get this barely audible volume (with sub's volume knob to 2:00 and above). I tried running audessy. When it starts to send a pulse tone to the subwoofer it does so 3 times. The first is barely audible with me next to it. The second is louder but still sooo quiet. The third is louder still but still way too quiet and then Audessy reports that the volume is too low to continue.
The Denon's LFE is set to 120hz.
Does anyone have any ideas on what I can try next? I can unscrew the amp on the sub to check for an anomaly but I wouldn't know what to look for. Help please!
