You can use your car amplifier to power an 8 phm load it will just most likely cut the power in half so if its 300w at 4 ohm you may get 150 at 8ohms... BUT them ls10s aren't subwoofers, they are full range speakers, just hook them to your avr's left and right front channels... Do you have some pics, to me it looks like they had a 5 channel surround sound, and then a-b ed to the 2 channel music system with the ls10's...
