HDMI Cable - Can I connect two together?
Discussion in 'A/V Interconnects, Cables & Power Conditioning' started by chgo36, Jan 9, 2009.
  1. chgo36 Audioholic Intern
    chgo36
    Nov 30, 2008
    26
    1
    I have a dilemma...I set up my home theatre a few months ago and ran HDMI from AVR to TV and ran it through a wall and it would be difficult to replace it. My question is....I want to move the location of my equipment/AVR etc about 6 feet but the current HDMI is not long enough. Is there a way to connect another HDMI cable to the existing one since I will have a tough time running a longer cable through the wall again?
    Help is appreciated?
  2. mperfct Audioholic Samurai
    mperfct
    May 21, 2007
    2,041
    752
    in the anaerobic zone.
    Check Monoprice.com. Here is one thing you can use: http://www.monoprice.com/products/p...=10240&cs_id=1024010&p_id=3345&seq=1&format=2
    Be conscious of how much you are extending. Anything past 30-35 feet you might consider using an active extender.
    • Like Like x 1
  3. mperfct Audioholic Samurai
    mperfct
    May 21, 2007
    2,041
    752
    They have them down to 3' to, I was just showing an example above.
  4. Midcow2 Banned
    Midcow2
    Feb 20, 2008
    1,899
    614
    Yes, get an HDMI extension cable
    Monoprice makes very good inexpensive cables. Get an HDMI extension cable. I am not sure how long you need, but here is a 10 ft extension cable for $11.31 the make other lengths.
    http://www.monoprice.com/products/p...=10240&cs_id=1024010&p_id=3343&seq=1&format=2
    Good Luck,
    MidCow2
    • Like Like x 1
Share This Page
  • rbhsound.com
  • Emotiva.com
  • CEDIA
