Hi All, newbie to this forum. I have a sound disappearing problem.
Yamaha RX-V371 Receiver,
Vizio E 321VL TV,
Chromecast,
Win7 Laptop with HDMI output
OK, so I feed the Laptop HDMI to the Yamaha HDMI-1, the Chromecast is plugged into HDMI-2 to the Yamaha and the HDMI output of the Yamaha goes to the VIZIO HDMI-1.
Sometimes the sound works on the TV and sometimes it does not. I cannot seem to find a connection or start up sequence that always works. Therefore I am not sure what is causing the issue.
I am a little hard of hearing, so I use the TV sound when watching movies with slightly muffled sound as the crappy TV speakers add just enough harshness to be useful.
It all works individually - sometimes. I looks to me like it depends on what setup was running when the Yamaha is turned off and then the Yamaha seems to decide what is allowed when I turn it back on. It seems like the Yamaha is deciding what sound I need over the HDMI connections when passing it through to the TV HDMI.
If I disconnect everything then connect just the laptop, OR the just Chromecast then it works just fine. There is something going weird with the combination when all plugged in.
I am lost with this one and I am no novice to hifi, TV or computers. Try as I might I cannot find a repeatable start up sequence to begin finding out what is happening with the sound.
Thoughts and suggestions would be very much appreciated.
Is there an inline adapter that I can put in series with the HDMI cable that would feed off the sound to a red/white RCA sockets and then I can use a headset plugged into them. I can't use the Receiver headphone output as it then disconnects the sound to the speakers and no one else in the room gets to hear anything.
OR
Can anyone tell me if this Receiver has a means of outputting the HDMI-cable sound directly? When I try using the audio output sockets it drops the HDMI signal completely when I select that with the remote.
Thanks
Harry
