Funk Audio 18.2 Dual 18" Sealed Subwoofer Preview
Discussion in 'Subwoofers' started by admin, Jan 16, 2013.
  1. admin Audioholics Robot Staff Member
    admin
    Apr 16, 2004
    172
    1,617
    Funk Audio, a relative newcomer in the ID subwoofer marketplace has just put its competition in checkmate. The Funk Audio 18.2 subwoofer is their latest and most advanced subwoofer design. It was designed to provide the ultimate in power, sound quality, and output, in a package so compact the amplification system has to be separate from the subwoofer itself. In Power Level Two configuration, will pump 9,600 watts into the dual 18" drivers (if you have enough wall current) allowing you to hit an ear drum busting 134 dB (2 meter GP). This is the kind of sub that will surely shatter Grandpa Simpsons teeth. With dual 4.5" voice coils, 44lb neodymium motor structures and 3" pk-pk excursion custom built drivers we have little reason to doubt the output claims of this subwoofer. Do you want us to review this beast? Let us know in the forums.
    [​IMG]
    Discuss "Funk Audio 18.2 Dual 18" Sealed Subwoofer Preview" here. Read the article.
    • Like Like x 1
  2. Steve81 Audioholic
    Steve81
    Aug 9, 2012
    4,048
    2,083
    Ohh I can't imagine why anyone would want to see a review of this :D
    With that kind of rated output, I'm mostly curious to see how it holds up against the Danley DTS-10.
  3. brianedm Audioholic General
    brianedm
    Apr 12, 2012
    1,101
    626
    Edmonton, Canada
    Oh Canada, our home and native land, true patriot love, in all thy sons command!
    • Like Like x 6
  4. 3db Audioholic Overlord
    3db
    Sep 7, 2002
    11,217
    2,669
    Ottawa Canada
    Brings a tear of pride to our eyes.
    3db,
    • Like Like x 1
  5. AcuDefTechGuy Audioholic Slumlord
    Jul 10, 2007
    19,870
    4,340
    Oklahoma City
    Answer: HELL YES! :D
    After you review the 18.0 first. :D
    I'm thinking four 18.0 vs two 18.2?
  6. Irvrobinson Audioholic Ninja
    Irvrobinson
    Dec 7, 2004
    3,552
    1,397
    Well, that blows the Revel out of the water.
    They're also having a sale right now on the 18.3, adding to my temptation.
    • Like Like x 4
  7. templemaners Senior Audioholic
    templemaners
    Feb 11, 2010
    549
    198
    That's a foolish question... of course you should review it. :D Would much rather have that sub than the $10K Revel.
    • Like Like x 2
  8. AcuDefTechGuy Audioholic Slumlord
    Jul 10, 2007
    19,870
    4,340
    Oklahoma City
    The F18.0 has 126dB max output vs the F18.3 which has 124dB max output. You would still go for the 18.3 ? :D
  9. AcuDefTechGuy Audioholic Slumlord
    Jul 10, 2007
    19,870
    4,340
    Oklahoma City
    I would like a head-to-head F18.0 vs F18.2 vs Rhythm2 vs JL vs SVS vs Paradigm. :D
  10. Irvrobinson Audioholic Ninja
    Irvrobinson
    Dec 7, 2004
    3,552
    1,397
    Huh? Their website says the 18.3 has as much output as two 18.0s.
  11. AcuDefTechGuy Audioholic Slumlord
    Jul 10, 2007
    19,870
    4,340
    Oklahoma City
    F18.3 spec:
    Variable tuning; 17-23hz, 15-21hz with curved sided option
    +/-3db variable from 13-30hz, to 40-150hz, customizable, contact us for more information
    124db maximum output at 2m ground plane
    F18.0 spec:
    Sealed
    +/-3db variable from 10-30hz, to 40-500hz, customizable, contact us for more information
    126db maximum output at 2m ground plane
    So not only does the F18.0 have higher max output, it also goes lower to 10Hz. The F18.3 goes down to 13Hz. :D
    Maybe it's a typo. :D
  12. agarwalro Audioholic Ninja
    agarwalro
    Jan 31, 2005
    3,973
    1,033
    Pittsburgh, PA
    I was not aware that the TSAD were Funk Audio's in house drivers. Very impressive!
  13. gene Audioholics Master Chief Administrator
    gene
    Jul 1, 2002
    7,977
    3,487
    Florida
    Funny as I was writing this, I was thinking the very same thing :)
    gene,
    • Like Like x 2
  14. 3db Audioholic Overlord
    3db
    Sep 7, 2002
    11,217
    2,669
    Ottawa Canada
    I'm thinking all of this speculation on our parts can ONLY be settled and satisfied by a thorough Audioholics subwoofer test and while your at it, line up all teh bad boys and etsablish a pecking order of "bad a?? s" subs from baddest to mildest.
    3db,
    • Like Like x 5
  15. funky waves Junior Audioholic
    funky waves
    Oct 21, 2010
    92
    95
    Halfmoon Bay BC
    The rated peak outputs are the highest peak output we have measured at any frequency between 10-125hz, the 18.3 does have as much output ~15-40hz as two 18.0, however due to it being a passive radiator(aka "ported") design it sacrifices useability below 13hz, is twice the size, and has reduced peak output in the upper bass region. This new 18.2 will overall match or exceed a pair of 18.0(frequency and power level dependent).
    • Like Like x 3
  16. Irvrobinson Audioholic Ninja
    Irvrobinson
    Dec 7, 2004
    3,552
    1,397
    Ha! Irv - 1, ADTG - 0. :)
    • Like Like x 3
  17. AcuDefTechGuy Audioholic Slumlord
    Jul 10, 2007
    19,870
    4,340
    Oklahoma City
    Whatev.......... :D
    The FACT IS, the F18.0 has a peak output rating of 126dB, and the F18.3 has a peak output rating of 124dB. FACT. :p
    • Like Like x 1
  18. jinjuku Moderator
    jinjuku
    Apr 6, 2007
    5,340
    1,700
    Louisville, KY
    Only curse words are available to me to display my utter sense of amazement at this beast. That is one small form factor given the performance.
  19. lsiberian Audioholic Overlord
    lsiberian
    Nov 17, 2008
    12,238
    3,167
    On A Bridge in Fort Worth
    This is a logical step I've found it's more cost effective normally to build a dual opposed than a P-Red sub and I really like the results.
  20. Nuance AH Audioholic General
    Nuance AH
    Aug 29, 2008
    1,085
    402
    Wisconsin
    Ahh - heck yes! :D
Share This Page
  • CEDIA
