Drivers: - 38cm (15") WCF Megawoofer, 30cm (12") WCF Megawoofer, 38cm (15") Passive Radiator
Rec. xover range: - 60 Hz - 250 Hz
Internal wiring: - 12 gauge Monster Cable
Impedance & Sensitivity: - 4 Ohm, 92 dB/1W/1m
Power handling: - 600 W rms / 4 Ohms, 20 W min.
Frequency response: - 17 Hz - 250 Hz +0/-3dB
Dimensions & Weight: - 58H x 81W x 48D cm, 63 kg, (23"H x 32"W x 19"D, 138 lbs)
Output levels and distortion: - max. 0.5% 20 Hz to 250 Hz / 1 W, min. 115 dB SPL / 1m at 20 Hz & 2.5%THD
Finishes: - standard genuine lite oak, dark oak
