If you want invest on good sound stay away from any package like that. They will produce sound, yes, but won't get you far. For good sound experience you want good speakers. Do you have a receiver to run your speakers already? If not, what is your budget for receiver? And for speakers? If your budget is low it might be better to start with stereo and upgrade when you can spend more as I suppose your goal is to have 5.1 sound system?
The original budget was *around* $1000 for the system, but after reading responses on a few other forums that has grown a bit. While Id like to stay close to the $1000, if the quality dramatically increased I wouldn't be opposed to moving to the $1500 range.
One suggestion from another forum was:
Kef Q100 at $299 or Kef Q300 at $399 from
Kefdirect
SVS Sub SB12 NSD for $399 from
SVSound
Denon S720 for $350 from Bestbuy, Crutchfield, Abt, Amazon and so on...
Kef's are on sale right now. Considering you get ID sub like SVS mentioned earlier.
2.0 - Kef Q300 @ 399
3.0 - Kef Q300 and Q600c @898
2.0 - Kef Q100 @ 299
3.0 - Kef Q100 and Q200C @ 698
5.0 - 2 Kef Q100 and Q200c @ 997
5.0 - 2 Kef Q300 and Q600c @ 1297
