I have a friend that is an "old guitar" player and we have this dissuasion often since he thinks I am nuts trying to get clean flat response. But, as an ex-biker, he likes nuts
When discussing guitars, I have a similar sentiment, clipping is part of the instrument and it should reproduce it as faithfully as possible.
I have played music with 20 DB peaks which would clip a 100 watt amp at reasonable listening levels.
You do not need to add much volume have high-peak demand.
The amp must handle instantaneous peaks, provide the required current and avoid compression.
I spent some time with a friends Pioneer SC07 ICE AVR (140 WPC).
Its soft clipping design produced a loud but lifeless sound when cranked driving his 3 way B&W's.
Soft clipping = compression.
He moved to two Outlaw M2200 (200 WPC) amps fed directly by an Oppo BDP-105 acting as a preamp.
The sound is much better clean, fast, adn dynamic. He used to turn it up until it ran out of gas.
Now, the volume control stays in the closer to 50%. With the dynamics in place it feels louder.
The lesson for me is that clipping and compression remove the dynamics and should be avoided even if they do not harm your speakers.
Compressed music, and I would argue a soft clipping amp, will deliver more constant power to drivers.
More constant power can lead to overheating and hurt drivers,
An amp running out of power can be turned up and may produce more high frequencies while being unable to power the bass.
The result is the same, more constant power to the tweeters and, of course, sucky lifeless sound.
- Rich
