With its beefy toroidal transformer power supply and classic short signal path Class A/B output topology, the Fusion Flex Amp delivers the power one can expect even into difficult loads as one can expect from an Emotiva Audio product. But, what really sets the Fusion Flex Amp apart is the wide variety of convenience and automation features.
Dual line level inputs let you connect two separate audio sources and you can switch between them by using the front panel controls, the remote control, or the IR and RS-232 remote control inputs. You can also set the Fusion Flex Amp to automatically switch to the active input! It can also be set to switch on automatically when it senses an audio signal. Another advantage is that you can use the buffered loop outputs to daisy chain together more Fusion Flex Amps to easily drive additional zones. This unit can be powered from any standard 115 VAC or 230 VAC power line. Talk about convenience!
What do you say? Is this what you've been waiting for?
Specifications:
- Channels: 2
- Inputs (stereo; line level): 2 (manually or automatically switched).
- Power Output (both channels driven).
- Signal to Noise Ratio: 95 dB.
- Frequency Response: 20 Hz to 20 kHz +/- 0.08 dB.
- Power requirements: 115 VAC / 230 VAC (+ / - 10%); selectable by rear panel switch.
- Dimensions (Unboxed): 8-1/2 " wide; 3" high (including feet);15" deep (including connectors).
- Dimensions (Boxed): 13" wide x 7" high x 18" deep.
- Weight (Unboxed): 11.2 lbs.
- Weight (Boxed): 15 lbs.
Price: $249.00
