First off...the forums that are dedicated to building your own Sub woofer are awesome, i have been reading everything i could find for weeks....I have been contemplating building my own speakers/sub woofer for a long time...
Now i have the woodworking tools and budget to give this a good effort.
I currently have a Jamo E8sub.5 sub woofer, it sounds pretty good IMO...its a sealed unit...
receiver is yamaha RX675.
I listen to it in the basement, its finished, 18' X 18', carpet flooring,....50/50 music and movies...
But I would like to upgrade to 2 sub woofers...move the JAMO upstairs...and at this point i think its DIY time...building the cabinets will not be a problem.
I have built most of the furniture in my house...which is stickley/mission style furniture...
After reading tons of info...i found this thread here...by jinjuku.....
forums.audioholics.com/forums/diy-corner-tips-techniques/78575-modeled-infinty-reference-1260w
This sounds like a very nice system...like the idea of the values comparison of DIY vs commercial...pretty much why i built my own furniture...cant afford what i like..so i learned how to build it...
I just have a couple of questions...
1.The box was basically 21x21x21 in size ...can i change the dimensions to be a longer box instead of a cube...without messing it up...still have it be a front driver...
2. If there was a higher budget available up to $1200 would it really be a benefit to upgrade any of the components...
just looking for some info from the more knowledgeable people...
A person could easily fall into the paralysis through analysis with this...
thanks...
