Digital Audio Output from LCD tv help
Discussion in 'A/V Interconnects, Cables & Power Conditioning' started by pjoseph, Aug 28, 2011.
  1. pjoseph Full Audioholic
    pjoseph
    Sep 28, 2007
    299
    22
    I noticed on the back of my tv there is a "digital audio out" the connection looks like what you would connect a rca cable to but it only has one.
    I also noticed my receiver has a "digital audio in" and only one just like the tv.
    These are not the optical ones either.
    what kind of cable connects to these? It looks like rca but I would think you would only get 1ch or mono output? but not sure
    thanks
  2. its phillip Audioholic Ninja
    its phillip
    Feb 5, 2010
    3,924
    1,255
    fort worth, tx
    that would be a digital coaxial cable
    it can carry compressed surround like dolby digital/dts or 2 channel pcm
    • Like Like x 1
  3. Adam Audioholic Jedi
    Adam
    Jul 5, 2006
    32,075
    11,912
    Tucson, Arizona
    To add to Phillip's info, you don't need to buy a special cable for that connection. A regular RCA cable will work. You can always buy a "digital coax" cable (such as this nice $4 one from Monoprice), but if you have an RCA cable around the house, you can get it hooked up right away.
    Adam,
    • Like Like x 1
  4. TLS Guy Audioholic Overlord
    Oct 30, 2007
    13,782
    5,250
    Benedict MN
    A digital RCA cable is 75 ohm termination, audio cables are 50 ohm. The 50 ohm cable works, but reflections and cancellations of data during transmission are much higher with the wrong cable. So using a 75 ohm cables with digital interconnections is much preferred.
    • Like Like x 1
  5. pjoseph Full Audioholic
    pjoseph
    Sep 28, 2007
    299
    22
    Thannks guys appreciate it,
    TLS: Would the cable that Adam posted above be what you would call preffered?
    thanks again
  6. its phillip Audioholic Ninja
    its phillip
    Feb 5, 2010
    3,924
    1,255
    fort worth, tx
    Yes, that is a 75ohm cable and would work just fine.
    • Like Like x 1
  7. BoredSysAdmin Audioholic Overlord
    BoredSysAdmin
    Aug 21, 2007
    11,130
    3,578
    New Joisey
    Yes, shielded 75ohm cable is what you need and monoprice is the place to get all sorts of cables you need.
    One thing to add is that most TV's digital out sends out only digital stereo, thou the interface itself is capable of 5.1 audio in Dolbly Digital/DTS
    • Like Like x 1
  8. TLS Guy Audioholic Overlord
    Oct 30, 2007
    13,782
    5,250
    Benedict MN
    That one will be just dandy.
    • Like Like x 1
  9. markw Audioholic Overlord
    markw
    Nov 26, 2003
    11,235
    3,051
    Joisey and Texas
    Let's not spread Audio Nervosa, shall we?
    Not necessarially. Audio interconnects can be anywhere between 50 and 110 ohms, and sometimes higher, and has been so since the 60's and probably before.
    Nowadays, with manufacturing for all cables being done in one plant, it would not make sense for them to use different cables for audio and video, particularly when 75 ohms works just fine for either. All they need do is put on different color ends.
    Bandwidth may be a different issue for long digital runs but, for the short distances involved in home connections, it's a moot point.
    • Like Like x 1
Share This Page
  • CEDIA
