That is not correct. Since the impedance of the woofers varies according to frequency, the woofers could have a lower impedance at the higher range than the lower range, so it is possible for a 2.5 way system to have a higher impedance in the deep bass than 4 ohms without having any problems with insensitivity at higher frequencies. Also, the frequencies you specify would not necessarily be the ones used for a particular design.
If you really want to know what is going on, it is best to look at an impedance curve for the speaker, not make a guess based upon the driver configuration.
In order to keep the impedance from dipping to four ohms, the speakers would have to be 16 ohms above 600 Hz, which would drop the sensitivity 3 db.
It is not the frequency impedance range you need to average, but the power
spectrum versus frequency The frequency power divide is 400 Hz. Below that area the impedance of a 2.5 way has to drop except for the narrow tuning peaks. As the impedance is halved the amp has to double the power output. So in a 2.5 way design the amp is providing around two thirds of its output into a four ohm load or less. That is the price of diffraction compensation. There is no free lunch.
The bottom line is that most receivers are only delivering half their rated output into properly diffraction compensated speakers. The good news is that this is only a 3db reduction in spl. The reason that the power is halved is that most receivers, although they may tolerate a four ohm load, they can not increase their current beyond what they can push into an eight ohm load at full power. Therefore there power output is halved into a four ohm load. A good external amp will be able to double its power into a four ohm load. This in a nutshell is the essence of the benefit of external amplification.
