Greetings to all. New member. I searched for this info in the forums but could not find a reference. Does anyone know a source for the strobe lamp on the DP 80 turntable? Any advice or info would be much appreciated.
This is now a problem, because of the advent of LED bulbs. LEDs will not work as a strobe light as they are powered from a power supply and not the AC directly.
I have the same problem with my Thorens TD 125 II.
There are two solutions.
The best is to use a strobe disc and get a fluorescent work lamp, and just set the speed when you need to.
The other is to load the RPM AP on your cell phone.
