christian_00x said:
My problem is that 120v fans are too noisy - that is why I'm interested in 12VDC fans Mudcat suggested earlier in this post. And especially the stealth computer fans because they are very quiet. Is there a way to get a computer fan to work with a 12VDC wall wart (1200mA transformer)?
How about an inexpensive small thermostat switch? Anyone have a lead for that?
Just wire up the red lead of the fan to the positive on your wall wart, and the black to the negative. The third wire, if there is one, can be ignored (the blue one), as it's just a speed monitoring lead which is used in PC motherboards so the machine knows if it's safe to stay powered on (most will shut off if they detect the CPU fan failed).
So remeber red (on some freak fans, yellow) = +, black = -. Watts = volts x amps, so a 2w 12v fan needs approx .16A of current (160mA)...this can easily be driven off a wall wart. Just remember to not exceed the current specs for your wall wart, and to wire fans in prarlell, not series. All but the most powerful computer fans can be powered off a 1000mA wall wart.
If you don't want to cut leads, buy a female socket made for that plug type of your wall wart (radioshack is good for this), and solder the fan leads to it, that way you can unplug the wall wart as needed.
For reference in terms of what a wall wart like that can do, I have an 80x80x40mm Vantec Tornado....possibly the mmost powerful DC 80mm fan ever made...84.1CFM...but at an ungodly noise level, as well as taking .76A of current....thats over 9 watts....and it can be ran off a 1000mA wall wart....if it can, so can your fans
edit: if you get 20-ish Db fans, it's advisable to not try to speed regulate them at first, since the airflow numbers from them are rather low. A 120mm vantec stealth puts out the kind of air a medium speed 80mm sunon can, although about 5-7Db quieter. So remeber a quiet fan is quiet for a reason...it moves less air. If you wish to move less air, get a 5v 1000mA wallwart and buy an AOC 120mm aluminum frame fan and run it at 5v. They run very very quiet and put out a good deal of air at that speed.
