Connect DVD to monitor/tuner
marricht
Hi. I have a Sony KX27PS1 monitor with seperate VTX100UB tuner. I have managed to connect a DVD player by connecting a lead from the scart socket on the DVD to the video input connector on the monitor.
However the TV/video now no longer works as I had to disconnect the existing lead from the video input connector on the monitor to the video connector (TVout) on the tuner. I tried using a normal scart lead from the DVD scart to the scart socket on the monitor, this did not work.
If this helps, there is a multi input connector (8 pin) & AV input/output connector (6 pin DIN) on the monitor. The tuner has a multi in and a multi out connector (8 pin), plus video connectors video in and monitor/tv out, and control/audio jacks.
Any ideas?
