Hello,
I am running a fairly powerful computer and I am noticing a lot of system noise coming through to my speakers (electrical noise when the system is under any kind of stress).
Currently my speakers are a pair of Krk Rokit 5's, with a Krk Rokit 10s subwoofer.
I am using a fairly cheap DAC, a Creative Soundblaster X-fi HD (USB DAC) which under normal situations shouldn't cause issues like this. So I ran an RCA to 3.5mm converter and tried running it straight to the computer 3.5mm jack, EXACT same sound - if not louder. My guess at this point was that nothing was shielding the signal going to my speakers.
Using the exact same 3.5mm jack I connected my Klipsch Image S4 earbuds and heard absolutely no noise. This same thing happened when I used another converter to connect it to my DAC.
So now my best guess is that the speakers are much more sensitive to the noise, what would be my best bet to get rid of the sound? I'm assuming a new DAC would be my first option but I'm not completely sure
Thanks in advance!
