Component Video Cable Used as a Subwoofer Cable
Discussion in 'A/V Interconnects, Cables & Power Conditioning' started by bsteve2, Sep 17, 2010.
  1. bsteve2 Audiophyte
    bsteve2
    Sep 17, 2010
    1
    0
    Arlington, TX
    Component video cables (separated) are being sold as a subwoofer speaker cable (go to ebay, subwoofer cable).
    Though both cable types have RCA connectors, what are the ramifications and concerns with this reverse application
  2. markw Audioholic Overlord
    markw
    Nov 26, 2003
    11,235
    3,051
    Joisey and Texas
    "reverse"??
    Dunno about that, but there are no problems using component video, composite video, or digital audio cables for audio purposes. ...and that includes use as subwoofer cables.
  3. m_vanmeter Full Audioholic
    m_vanmeter
    Sep 7, 2007
    469
    110
    central Kentucky
  4. markw Audioholic Overlord
    markw
    Nov 26, 2003
    11,235
    3,051
    Joisey and Texas
    Just a question...
    Why "should" one use a digital audio cable for a subwoofer, which was the question?
    FWIW, virtually any interconnect "will" work fine for a digital cable for distances generaly encountered in home situations. Been there, done that.
    • Like Like x 1
  5. j_garcia Audioholic Jedi
    Jul 11, 2005
    26,558
    5,735
    You actually have it backwards in terms of "reverse". A video cable will ALWAYS work for analog audio, while an analog audio cable does not require the same specs and may not work for video.
  6. highfigh Audioholic Warlord
    Sep 14, 2008
    8,032
    1,875
    Milwaukee area
    When did subwoofer cables start to carry digital audio signal?
  7. highfigh Audioholic Warlord
    Sep 14, 2008
    8,032
    1,875
    Milwaukee area
    There would be no ramifications, unless the subwoofer just has its own ideas of which type of cable is correct and refuses to take the signal it's being fed.
    Grab a piece of coax and a pair of compression RCA ends, install the ends and be done with it. If you just want to use up a component video cable because it's available, go ahead. If you have a piece of coax that was already terminated, get a pair of F-RCA adapters and put them on, plug it in and use that. RG59 or RG6 will work fine and if you can hide it, even better. Regular coax is used for audio all the time and nobody will ever hear the difference between that and all of the other stuff.
  8. bandphan Banned
    bandphan
    Dec 13, 2007
    6,619
    2,363
    in a haze
    When its coax :) And you know that... btw the way I understand where you were going.
  9. lsiberian Audioholic Overlord
    lsiberian
    Nov 17, 2008
    12,238
    3,167
    On A Bridge in Fort Worth
    maybe that's why my sub sounds so good.:D I use one for my sub. You'll be fine. But most folks have plenty of RCA cables. Any RCA or coaxial type will work.
  10. highfigh Audioholic Warlord
    Sep 14, 2008
    8,032
    1,875
    Milwaukee area
    Oh, you mean the cables that have 'Digital' all over the packaging, right? "Digital headphones", "Digital" on speakers, "Digital cables" for connecting the analog audio from a CD or DVD player, etc?
    • Like Like x 1
Share This Page
  • CEDIA
