Clearance for rear ported bookshelves
Good4it
Good4it
How much should the rear port on a bookshelf speaker be ahead, minimum, of a solid surface?
It's got a 5.5" woofer. How far for a 6.5 speaker?
William Lemmerhirt
William Lemmerhirt
Huh...pretty sure there were no sizes in op when i responded. In any case I meant the port.
Good4it
Good4it
Just to be clear "rear ported" refers to speakers with ports in the rear of the speaker,
not to speakers in the rear of the room.
Yes, and to be clear generally anywhere from the equivalent distance of the port diameter (or a diameter and a half) to a few inches clearance is sufficient; ideally even more than that for better sound.
