Hello everyone,
I have been having this annoying problem for some time now. My center channel speaker completely cuts out intermittantly. It seems to happen pretty frequently at mid volume while watching DVDs (optical digital connection from DVR to Rec.), and also while watching TV at various volumes (analog RCA from cable box to Rec.). If I crank the volume quickly from the receiver it will kick on, then I can drop the volume to normal. Sometimes I'll go though a whole movie and it will be fine and other times it will happen several times.
I'm was thinking its a problem with the crossover network in my center channel speaker since I've had the same problem with two different receivers. Tonight I pulled the speaker apart and checked all connections and they looked good. I hooked it back up and wiggled wires and didn't lose sound.
Anyone have any other suggestions?
Thanks in advance!
Paul
