Hello all..I'm looking for your thoughts on recommended ceiling speakers, placement and receivers, for my basement bar. I will be using the audio for mainly music and sports events, no movies. The space is an open concept design. The ceiling is roughly 8 ft high and will have stained concrete floors. The volume will be between low volume all the way up to party time...hehe,,after all it's going to be a bar
. Also do you guys recommend adding separate subs to the mix? Any advice would be great and thank you ahead of time !!!!! As for the space it is roughly 1300 sq ft. My budget is between 3 - 6k.
