Hello everyone, first post here.
My old (read: close to 30 years!) Boston Acoustics speakers have been dying a slow death for the past couple of years, so I went ahead and bought a pair of Cambridge Audio S30 speakers to use with a Yamaha RX-396RDS receiver.
The old speakers had an impedance rating of 8 ohms. The new ones, according to the manual, are rated at '4-8' ohms.
My question is this: should I change the switch on the back of the receiver from its current 8 ohm setting to the 4 ohm one? A quick google search yielded interesting results - apparently its better to just leave the switch at the 8 ohm setting, since the lower setting just cuts down on rail voltages to keep the unit from overheating, resulting in worse sound.
Is this correct? Should I leave the switch at 8 ohms or should I drop it down to 4 ohms?
Thanks in advance!!!
