When you look for a Bluetooth speaker, there are certain features that you should take into consideration before making a final decision. To me, the Air 200 from Cambridge Audio is one of those speakers that offers a lot of useful features. It is an AirPlay, Wi-Fi and Bluetooth speaker, featuring a built-in subwoofer for better bass response and 200W class D amplifier. This unit also supports aptX which is a higher quality version of standard Bluetooth that enables CD quality playback of high-bitrate digital audio files.
This speaker has a rigid enclosure that is acoustically damped. Its cabinet is designed to help eliminate vibration and distortion. So there you have it. If you are looking for a Bluetooth speaker, you should take a look at the Air 200.
FEATURES:
- Apple AirPlay technology.
- Bluetooth technology (aptX, AAC and SBC compatible).
- Internet radio.
- Aux input (RCA and 3.5mm).
- Digital Signal Processing (DSP).
- High quality class D amplifier.
- Remote control.
- Adjustable bass control.
SPECIFICATION:
- Drive units: 2 x 57mm (2.25’’) Balanced Mode Radiator (BMR) drivers 1 x 165mm (6.5’’) subwoofer.
- Amplifier power output: 200W
- Input voltage: 100V – 240V (50/60Hz)
- Standby power consumption: <0.5W
- Auto Power Down (APD): Adjustable from 23hrs 45minutes to 15 minutes, or OFF.
- Wi-Fi: IEEE 802.11 b/g
- Wi-fi encryption: WEP, WPA, WPA2.
- Ethernet: IEEE 802.3, 10 Base-T or 100 Base-T.
- Dimensions (WxHxD): 17.7’’ x 8.7’’ x 6.9’’.
- Weight: 11.2 lbs.
- AirPlay compatibility: AirPlay works with iPhone, iPad, and iPod touch with iOS 4.3.3 or later, Mac with OS X Mountain Lion, and Mac and PC with iTunes 10.2.2 or later.
Price: $499.99
