I have a C weighted spl meter I've used to set the level of my setup. Playing pink noise through the receiver, the sub measures about 4-5dB lower, turning it up the 5dB sounds excessively boomy and loud. My mains are good down to 60hz, playing a 60, 70, and 80hz tone through either the fronts or subs registers within +- 3dB on the spl meter, making me think the meter is probably just less sensitive at sub 60hz. The in room response of the sub is accurate within ~6dB from 100hz-30hz at listening position which is pretty good considering less than ideal room dimensions.
Any idea why the pink noise registers a bit lower than pure sine waves?
Sent from my SM-G360T1 using Tapatalk
