Here is an article that doesnt say otherwise about an amp in bridged mode seeing half ohm.
I'm not quite sure what you're saying here but you can believe what you want. We're only going by years of experience here. In my case, around 45 years. No idea exactly how many the others have.
Keep in mind that automotive amps are many times speced down to two ohms. Most home amps are not. Learn a bit more about power supplies and you might understand.
Here's some snippits from your second article.
Many people feel that they have to connect every multi-channel amplifier they own (generally 2 ohm stereo stable or 4 ohm mono stable) in a 2 ohm mono configuration. These are generally the same people who have owned (and destroyed) many amplifiers. This is because very few amplifiers (especially Class A/B amplifier) are capable of safely driving a 2 ohm mono load. The reason why a 2 ohm mono configuration is dangerous to most multi-channel amplifiers will be covered a bit later."
and...
"As was previously stated, a 4 ohm
mono load is the same as a 2 ohm
stereo load as far as the amplifier is concerned. Looking at the next diagram, configuration 'x' shows a 2 ohm stereo load."
