Johnny2Bad
Johnny2Bad
These kind of power problems are extremely hard on any power supply, whether it's your computer or something else. A UPS is highly recommended, and consider each event as one of your power supply's nine lives.
Irvrobinson
Irvrobinson
Why is this the case?
speakerman39
speakerman39
UPS units aren't too pricey usually. If you have a projector, then UPS is mandatory. For most other electronics, it is a luxury.
By far, I prefer the APC brand!
Yeah, APC seems to be very popular. Will look into it asap. Thanks for the recommendation.
Cheers,
Phil
NINaudio
NINaudio
I recently bought this cyberpower unit and it worked flawlessly when my power went out for an hour and a half the other day. Not sure how long it would have allowed my pc to run, but I had ample time to close everything and shut it down normally. I know they also have a program you can use that will shut your computer down automatically in the event of a power outage.
speakerman39
speakerman39
Thanks for the recommendation. Will look at it much closer. Good to hear things got shut down properly.
Cheers,
Phil
