I'm looking to upgrade my PC audio system by adding in a quality subwoofer and would like some recommendations for which subwoofer would be best to invest in for my set-up and needs. I have
Swan M200 MKIII speakers on 36 inch speaker stands located 4 and a half feet apart on either side of my computer desk and they're run through the onboard sound on my
ASUS P9X79 WS Motherboard.
The room measures 21 feet 5 inches in length, 12 feet 9 inches in width and the ceiling is 9 feet tall. Most of the time I'll be sitting in front of my computer at my desk so the speakers will be a little under 4 feet away from me on either side. Here are a few pictures of the room and my set-up (these were taken a year ago but the set up now is more or less the same).
I'm going to be using this 90% for music, and while I do watch some TV/movies on my PC, the purpose of the subwoofer is not for a home theater set up. Basically I want to add extra bass and volume to my sound system while still retaining high end sound quality. I’m not an extreme basshead and only 30% of the music I listen to is hip-hop/bass-heavy, but it would be nice to get a subwoofer I could really feel and that would rattle the pictures on the walls…or, for example, make a song like
this really pop, something I believe a quality subwoofer would help substantially.
My subwoofer budget is ideally under $400 but I'm willing to make an exception up to $500 if it's absolutely heads and shoulders above the rest in quality.
These are the 9 subwoofers (mostly) under $400 that I've found highly recommended after a few hours of research tonight, but I'm not at all sure which would be the best to go with for my setup and needs so any help/advice would be much appreciated. Also, if there's another option not listed here that would be better I'd be very open to considering that as well.
(not in any particular order.)
1.
HSU STF-2 - $375 new
2.
BIC Acoustech PL-200 - $329 new
3.
Klipsch RW-12d - $325 used (discontinued)
4.
Outlaw M8 - $249 new
5.
Elemental Designs A2-300 - $215 - $250 used (discontinued)
6.
SVS SB-1000 - $499 new
7.
SVS PB-1000 - $499 new
8.
Emotiva X-Ref 10 - $399 new (discontinued - can't find any links to used ones for sale)
9.
Paradigm PW2200 - $430 used (discontinued)
The other thing to take into consideration is I'm not sure how to hook up the Swan M200 MKIII speakers to the subwoofer/my PC. Some of the options I've seen for how to hook up speakers such as these with a subwoofer and a PC seem quite complicated and pricey, and while I don’t want to go with a cheapo way that will degrade the sound quality any, I also don’t want to spend hundreds on simply connecting the speakers/subwoofer and PC, either.
So, with all this taken into consideration, what would be my best option? Thanks in advance for any help!
P.S.
Given the pictures of the room above, what would be the best placement for the sub? I was thinking under the center of the desk but maybe some more experienced audio pros could help me out there as well.
