I have just installed a 5.1 surround sound system in my home office, which I will use for gaming and movies. In the ceiling I have 3 Polk VT60 for the left center and right speaker, 2 Polk MC60 for the rear surround and a Polk PSW-108 sub all hooked up to a Sony STR-DE985 Receiver. I got the receiver for free from someone and it is fully functional. The receiver does not auto set up the speakers like the receiver in the main room of my house. So I am manually setting them up. This is where I get lost in the EQ setting it ask for the following
Under the EQ I have these options:
Front Bass -10dB through +10dB
Front Bass 99 Hz through 1.0kHz
Front Mid -10dB through +10dB
Front Mid 198Hz through 10kHz
Front Treble -10dB through +10dB
Front Treble 1kHz through 10kHz
Center Bass -10dB through +10dB
Center Bass 99 Hz through 1.0kHz
Center Mid -10dB through +10dB
Center Mid 198Hz through 10kHz
Center Treble -10dB through +10dB
Center Treble 1kHz through 10kHz
Surround Bass -10dB through +10dB
Surround Bass 99Hz through 1.0kHz
Surround Treble -10dB through +10dB
Surround Treble 1kHz-10kHz
Under level I have these options:
Center Level -10dB through +10dB
Surr L Level -10dB through +10dB
Surr R Level -10dB through +10dB
S. Woofer Level -10dB through +10dB
LFE Mix Level off or -20db through 0dB
D. Range Comp .1 through .9, STD, Max or off
the polk audio MC60 specs are 100 watts, 91dB, 8ohm, 60-20,000Hz
The polk audio VT60 specs are 100 watts, 89dB, 8 ohm 33-27,000Hz
The Polk Audio Psw-108 specs are 100 watts, 8 ohm, 35-200Hz
What do all these settings mean, and what should I have them set at? This is like looking at a foreign language. I tried to look this up but all I get is car audio.
