Bash 300 or 500 for klipsch rw-12
Tom V.
>>>That's pushing it for me. You can get that sub used for less than that (but no warranty) and NEW for $100 more. Klipsch aren't known for their subs, so it is kind of difficult to recommend that path, though it is still likely the least expensive option and I can relate to that.<<<
I agree, that is RIGHT on the edge of go/no go. If you were happy with the bass before the failure I'd probably lean towards the amp fix. However I'd like a good idea of the time frame involved to get the amp returned. Does a brand new one come with more than a one year warranty? If so, maybe it is worth the extra $100? You'd have your old box and driver too...a DIYer might be willing to offer you a bit for that?
>>>Tom V.
Are you the Tom V from SVS? If so, What happened?<<<
Yes, I'll send you a PM to keep on topic.
Tom V.
