TLS guy is spot-on about drills. As a machinist for over 40 years I'll confirm that many a brand new one, even one labeled "Vermont American" found in many hardware stores can have a very poor grind geometry. They may look OK to the untrained eye and make holes in wood OK, but to someone who actually makes a living with high performance drills in a machine shop...they are garbage. I might use one to pick metal chips out of the soles of my shoes, that's about it.
Cutting speed of drills made from HSS or HSS-Co (high speed steel or high speed steel with cobalt the tool steel material they are made of) is usually 30 to 100 surface feet per minute for most steels. That would be 727 to 2425 rpm. Most hand held drill (motors) run at either 1725, 3450, or vary between those. Some better battery powered ones may go slower.
I grab a lot of drills for my home shop off eBay. Look for brands Precision Twist Drill, Titex, Guhring, Michigan Drill, Ohio Drill, Nachi, Mitsubishi, Triumph, etc. There are a lot of junk drills with American or Japanese sounding names, found at Home Depot and others, such as Cobalt. A lot of the power tool makers offer "kits" of drills, often now with hex shanks. Those are almost all junk.
