Yep, the hard reset did the trick. I think because i was using Audyssy pro kit to begin with, it was conflicting with the initial setup of standard Audyssey and the standard mic.The reason i wanted to use the standard mic is that i needed to check a phase error i was getting with the pro kit.So to sum it all up i would say "If we have loaded measurements with the pro kit to our Avp's and decide to start using the basic mic that came with the Avp then a hard reset is required". Thanks guys
