The wireless solutions coming out now are pretty cool. I am using a different brand's unamplified rec hooked up to an old NAD to power my surrounds. Had a bad ground loop, but once I took care of that the sound is pretty good. Definitely adequate for the surround duties where I'm using it. Much, much better than the amplified rocketfish solution I tried a few years ago.
I like these new amplified solutions, however I think they may be slightly off the mark for my usage. If it's a stereo amp/rec then you still have wires running a distance to at least one of your speakers. I think single channel rec/amps would allow for more flexible and unobtrusive placement. Maybe one that could act as a base to place the speaker on, or if small/light enough to attach to the keyhole mount on the back of a speaker.
