Model:Energy act cinema sat and center
System Type: Magnetically shielded 2-way speaker
Recommended Amplifier Power: 20 - 100 watts (RMS / Channel)
Nominal Impedence: 8 ohms nominal / 4.5 ohms minimum
Frequency Response: 100Hz-20KHz +/-3 dB
(+/- 3db):
Useable Bass Response
(-10db Anechoic): 90Hz
Sensitivity
anechoic 86
(2 speakers in a typical room): 89
Crossover Point: 2.8kHz
Components:
Tweeter: 1/2" (13mm) Textile Dome - Neodymium Magnet
Woofer: 3-1/2" (9 cm) High Performance Injection Molded Polypropylene Cone w/ rubber surrounds - 9oz magnet structure
Overall Dimensions:
(Dual 3-1/2" (9 cm) High Performance Injection Molded Polypropylene Cone w/ rubber surrounds - 9oz magnet structure on Center)
7 x 4-1/2 x 4-1/2"
4.5 x 11.2 x 4.5 (center)
Cabinet Finishes: Black with Silver front baffle
Approx. Shipping Weight:
2.6 lbs ; 1.2 kg
4.9 lbs; 2.2 kg
(1 speaker)
Included Accessories Wall/ceiling mount bracket
act sub
SYSTEM TYPE Powered subwoofer
AMPLIFIER POWER OUTPUT 80 Watts RMS, 300 watts dynamic internal amplifier
WOOFER 8" Ribbed Elliptical Surround woofer
VOICE COIL DIAMETER 1"
MAXIMUM DRIVER EXCURSION 1.49" PEAK TO PEAK
FREQUENCY RESPONSE 30Hz - 120Hz +/-3dB
INPUTS LOW LEVEL, STEREO HIGH LEVEL (SPEAKER LEVEL)
CROSSOVER FILTER SWITCH NO
POWER SWITCH OFF or AUTO or ON
DIMENSIONS 16-1/4 x 10 x 14
CABINET WEIGHT 24 lbs, 10.9 kg
FINISH Shadow Silver
