If you’re looking for some home theater speakers with a minimalist look, then you should take a look at the Intimus L6-IW In-Wall Speaker from Aperion Audio.
The Intimus L6-IW In-Wall speakes features a 6.5" woven-fiberglass dual-voice coil woofer, an aimable silk-dome tweeter, as well as bass and treble adjustment switches, normally found on more expensive in-wall speakers. Plus, the L6-IW is voice-matched to blend with all Intimus speakers. Very good appearance, articulate sound, easy to install, awesome warranty and awesome customer support. You just can't ask for more. Check it out!
Key Features:
- 6.5" long-throw, woven-fiberglass, dual-voice coil woofer.
- 1" aimable audiophile grade silk-dome tweeter.
- Treble equalization switches.
- Ten Year Warranty30-Day No-Risk In-Home Audition.
- FREE SHIPPING - a $18 value per pair.
- FREE lifetime customer support.
Specifications:
- Frequency Response: (+/- 3dB) 80Hz to 20,000Hz - (+/- 6dB) 50Hz to 20,000Hz.
- Impedance: 8 Ohms.
- Sensitivity: 88 dB
- Recommended Power: 20-200 Watts.
- Tweeter: 1” Silk Tweeter.
- Midrange: 6.5” fiberglass cone voice coil #1.
- Woofer: 6.5” fiberglass cone voice coil #1 + #2.
- Driver Configuration: 2-1/2-Way.
- Enclosure Type: In-Wall.
- Dimensions: 7.75" Wide X 11.6" Tall x 3 1/4" Deep.
- Product Family: Intimus Architectural.
- Placement Location: Front Speakers, Rear Speakers.
- Weight: 4.0 lbs.
- Dimensions: 6-3/4" X 10-3/4".
Price: $298.00/pair
Have you heard a pair of these speakers in action?
