Aperion Audio Intimus L6-IC In-Ceiling Speakers Overview
HTKamikazee
Audioholics Sheriff
As I said in another thread, I've seen many people buying in-ceiling speakers. I believe it is because of the arival of new audio formats like Atmos where ceiling speakers could be suggested for better sound dispersion and imaging. Aperion Audio carries some pretty good speakers that you can consider like the Intimus L6-IC In-Ceiling speakers. These speakers do not only sound good but, they also look good.
These speakers include features not normally found in architectural speakers such as dual-voice coil, woven-fiberglass woofer, an aimable silk-dome tweeter, and a treble adjustment switch. They are also matched to blend with all other Intimus speakers. If you are installing in-ceiling speakers in your HT room or any other purpose, these might be your ticket!
Key Features:
  • Aimable 1" Audiophile-Grade Silk-Dome Tweeter.
  • 6.5" Long-Throw Dual Voice Coil Woofer.
  • Customizable High Frequency Equalization.
  • Paintable Frame and Grille.
  • In-Ceiling Mounting System
Specifications:
  • Frequency Response: (+/- 3dB) 80-20,000 Hz -- (+/- 6dB) 50-22,000 Hz.
  • Impedance: 8 Ohms.
  • Sensitivity: 88 dB.
  • Recommended Power: 20-200 Watts.
  • Tweeter: 1” Silk Tweeter.
  • Woofer: 6.5” Dual Voice Coil Woven Fiberglass Mid-Woofer.
  • Driver Configuration: 2-Way.
  • Enclosure Type: Infinite Baffle Design.
  • Dimensions: 8.9" Diameter x 5" Deep.
  • Cut Out Dimensions: 8" Round.
  • Weight: 4.0 lbs.
Price: $298.00/pair
