Ok, imagine this!
Lets say that after a long negotiation and for being a good boy, you finally got your wife's approval to buy a new subwoofer. But because your system is in the living room, she has a couple of non-negotiable conditions:
First, she doesn't want to see a huge box ruining the room's decor. And second, she doesn't want to see "ugly" cables running around the floor but, the only available space you have is far from your receiver or amplifier. At that point, she might be thinking "yesss, I got him!", "Checkmate!!!". Hehehe (evil laugh). So, you ask yourself; Ohhh no, how can I make this happen?
Relax, my friend! Our friends from Aperion Audio have an awesome solution waiting for you...... The Bravus II 10D Powered Wireless Subwoofer.
This sub features dual 10” drivers and offers the performance you’d expect from a much larger subwoofer. It has been squeezed into a small cabinet for the perfect fit in any medium to large room without while raising WAF. Then, add 500 watts of digital power and you’ve got a sub that will take your music and movies to new highs… and lows. So, now you've got a solution that is going to give you big sound in a smaller footprint, and no cables to bother the lady. Aperion Audio has given us a win-win solution with the Bravus II 10D Powered Wireless Subwoofer. Now we can finally say; Problem Solved!
Here are some Key Features:
- Wireless Connection to your AV Receiver via the Zona Home Audio Link.
- USB power jack for easy wireless connection.
- Single down-firing active 10" aluminum driver.
- Dual side-firing 10" aluminum passive radiators.
- 500 watt class D amplifier.
- Small internally braced 3/4" HDF sealed enclosure.
- Virtually vibration-free cabinet.
- TEN YEAR WARRANTY (two years on the amplifier).
- FREE SHIPPING - a $55 value.
- FREE lifetime technical support
System specifications:
- Frequency Response: (- 3dB) 27Hz - 180Hz (- 6dB) 25Hz - 200Hz.
- Sample Rate: Zona HAL: 16-bit depth and 48 KHz sampling.
- Latency: Low, at 18 ms.
- Wireless Band: 2.4 GHz.
- Amplifier Power: 500W RMS.
- Woofer: 10", high-excursion aluminum driver with dual 10” passive radiators.
- Driver Configuration: Single Driver with Dual Passive Radiators.
- Enclosure Type: Sealed and Internally Braced, 1" HDF.
- Dimensions: 15"H x 13.5" W x 13.5" D (with feet attached).
- Weight: 44.0 lbs.
- Finish: Gloss Black.
Price: $698.00
Any takers??? If you already have one, let us know what you think about this product!
